I have a codec AC3 from AVI Xform on GSpot that says it is misconfigured. I have installed a different AC3 filter from here![]()
but the other AC3 message is still there. How can I uninstall the original AC3 I have searched and cannot find it. Because of this my film will not convert as it says audio format unsupported
the first ac3 you installed,was it one that you register the filter?
to remove it you need to unregister it.download this http://www.glasso.dk/ac3.htm extract and double click on the Un registerfilters(the one that aplys).
...but it shouldn't matter which ac3 you install.the app that your useing may not support ac3.if you trying it with virtualdub,use virtualdubmod instead. -
I have tried virtualdubmod but i cannot work out how to do it. I am new to this. I have been using avs converter so it is simple just load and convert
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 15:39 -
Which codec should I use?
By TSWatson in forum ProgrammingReplies: 9Last Post: 23rd Apr 2010, 08:25 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41
