I know the subject sounds a little easy but read on.
I have the 3 Stooges double Feature DVD. It is 2 discs. I used DVD Decrypter to put them on my HD. Each rip is just under 2 gigs.
My question, is there a way to combine both of these separate rips into 1 dvd burn?
DVDShrink will do that easily if you don't want menus.
The other alternative is to use an authoring program that
will accept VOBs as input.
DVDlab
TMPGenc DVD Author
MF2
There are possible problems with the second approach.
....and why is a Dvd RIP UNDER 2 GIGS ?
Combining multiple titles into one
By augerpro in forum Video ConversionReplies: 2Last Post: 22nd Sep 2011, 17:50 -
Combining Multiple PGC's
By wulf109 in forum Authoring (DVD)Replies: 1Last Post: 25th Mar 2011, 23:38 -
Combining Mini-DVDs into 1 DVD
By Jinga in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2010, 12:06 -
Combining two DVDs
By avz10 in forum EditingReplies: 2Last Post: 5th Oct 2008, 11:33 -
Combining multiple Titles into 1 (re-authoring a dvd)
By Liquid Drum Theater in forum Authoring (DVD)Replies: 33Last Post: 6th Sep 2007, 02:00
