Can anyone advise if the following process will be free of any re-encoding, A/D conversion etc. In other words can I get lossless copies?
Burn RAM disc in E60 from SVHS tapes ; put RAM disc into E80/100 and push back to hard drive ; edit out some scenes ; burn RAM copies in the E100/80.
Will the RAMS from the E100/80 be lossless copies of the original recorded on the E60?
Somebody must know!! Please put me out of my misery. I have to burn the discs now and can only buy the E60 here. When I emigrate I'll get the hard drive machine to do the final editing and copies.
Please help!
ozalien,
I understand you can't get the manual to download from the Panasonic web site, so let me pop a piece of it in here:
Looks like your only choice for going from DVD-RAM to HDD is the "High Speed" mode, which is your "lossless" mode. Presuming you'd be able to go "High Speed" from the HDD to DVD-R, I think you got yourself a plan!
thoots -
Is the manual for the DMR-E100HS available online? I have not been able to find it (doesn't seem to be on the Amazon website yet).
nextlife -
Well, I can't find it on Panasonic's site:Originally Posted by nextlife1
http://www.pasc.panasonic.com/OperMan/FindManual.asp?bhcd2=1068184242
You can get the one for the DMR-E80H, though -- just search for exactly that:
DMR-E80H
I'd recommend selecting the "Save to your PC" button....
That ought to get you at least "most" of the information from the E100H manual....
Hope that helps!
thoots -
If you need the E80 or E100 manuals in English or French go here:
http://www.panasonic.ca/english/sandd/SoftwareQuery.asp
Put in DMRE for the model number and a list will be generated.
Download what you need... -
Wow--thanks oldfart13. I've been looking for that for a while. Very helpful!
nextlife
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
RAM usage drops drastically after encoding
By Moontrash in forum ComputerReplies: 2Last Post: 2nd Dec 2010, 21:16 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Converting DVD-RAM to DVD WITHOUT re-encoding?
By MePerson in forum Authoring (DVD)Replies: 13Last Post: 27th Jun 2008, 13:38 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
