Saw a thread in another forum where multiple users had used hacked firmware to "convert" their Sony 500A,500AX,U10A, or U12A to a Lite-On LDW-400D DVDRW, since they are all the same drive mechanically. Their main reason was to improve their burner's compatibility with cheap 4X media,since the Lite-On's firmware was considered significantly better at that task. I have long resented my 500AX's fussiness limiting me to expensive(TDK,Maxell,Taiyo Yuden) media. So I gritted my teeth and did the flash. (I had the reversal hacked firmware to put it back again if I didn't like the results). It seems to have worked. I burned a cheapo 4x disk successfully. Need to do more tests to really tell the tale. For those interested, here are the links(hope I'm not breaking some rule):
Firmware- http://www.sonycrx2xx.org/DRU500a/500aFAQ.htm
Threads- http://forum.doom9.org/showthread.php?s=329557d83b468e1f18982fb343b09d5a&threadid=61070
http://forum.rpc1.org/viewtopic.php?t=17675
I would welcome all comments from those who have also done the "upgrade"...MarsOfOld
PS: I posted this in the Media forum since the whole purpose of it was to improve the drive's media compatibility. Hope the mods don't move it...
Results 1 to 1 of 1
liteon hbs112 firmware
By davechubb in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2012, 13:19 -
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 16:32 -
sony DAV-DZ100 Firmware update problem
By kanu in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2009, 06:15 -
FIRMWARE for SONY DVD
By yangp in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2008, 15:44 -
FIRMWARE SONY DVP-k82p
By xunter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2008, 10:37
