Is there anyway to see the size of a DVD Workshop project ? I want to avoid adding video and photos and then discover at the end that it won't all fit onto one DVD. Thanks.
I keep a rough running total in my head. :c) But you can check where you are at any time by going to FINISH, looking at reported size, and then canceling out of it.
It always rounds up a bit (ex. 4.14 becomes 4.2) so you can often add small items without it showing a change.
Also, keep in mind, you can always make oversized DVD folders on harddrive and then shrink down to fit with a transcoder if you happen to go over. Not an ideal way, but it would save redoing - if you go just a bit over - and the quality change would be minimal.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 13:49 -
sony vegas project size
By chidoug in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 00:22
