just was wondering if any one used any basic effects programmes....just after some names and some feedback on them.
thanks.
Little Mick
"We want the finest wines available to humanity, and we want them now!"
Ulead Video Studio 6 and 7. There aree some guides here on a few of the functions. (trial ware)
Hello. -
Avid Free DV http://www.avid.com/freedv/index.asp
Zwei-Stein free compositing http://www.thugsatbay.com/software/index.html
What kind of basic effects are you looking for, and what file format will you be using? -
Adobe After Effects is a good one, very deep and a ton of plugins.
Vegas has a good selection of effects built in, and there are a few plugins floating around for it. I like this one quite a bit, I find the learning curve is much easier, and it covers editing, in-depth audio work, compositing and titling all in one application.
of course, there are a ton of filters for Virtualdub.
Particle Illusion is a nice one as well for doing particle effects - explosions, fire, waterfalls, etc. if you can find the right back issue of Digit magazine from August, the SE version was included free on the cover disc - not bad, a $99 version for around $13.
depends on what kind of effects you are looking for....- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Adobe After Effects is a superb program but very expensive -- around $600. You might want to give AviSynth a whirl. It has a much higher learning curve but lets you do many of the same things.
I like AviSynth as well. It also does a few things Video Studio cannot do. Like open certain DivX video, display four videos as one, etc. And Vs 7 stillonly costs around $100.00. One of these days I hope to meet someone who can afford Adobe Premiere and After Effects.
Hello.
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 14:46 -
Digital convertor problem - very, very basic
By camera21 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2009, 18:47 -
Downloading films/tv programmes
By DrAlanStatham in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2008, 19:07 -
Recording music,editing,adding sound effects ect...
By f-zer0 in forum Off topicReplies: 6Last Post: 20th May 2008, 07:44 -
Adding special effects like countdown etc (National Geographic)
By chico34 in forum EditingReplies: 0Last Post: 15th Feb 2008, 19:00
