hi
each time i finished converting a dvd to avi (using any dvd authoring software e.g xmpeg, imtoo dvd encoder, dvd2avi, etc) i always get an indexing error.
I can play the movie file fine until the film film ends but i can never delete or modify the file again. the error message i get is: error modifying/deleting file because another program is accessing it.
i think this is because of an indexing error that prevents the file from closing properly after is has been played.
am i doing something wrong whilst encoding? please help.
rendy
this is a well known windows xp problem re-boot then delete the "carp" and you should be fine.
The electronic components of the power part adopted a lot of Rubycons.
VLC and AVI re-indexing
By Seeker47 in forum Video ConversionReplies: 7Last Post: 13th Apr 2011, 22:56 -
audio indexing for search
By ponzonik in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2010, 11:14 -
Options for PGC indexing?
By Gew in forum DVD RippingReplies: 3Last Post: 22nd Feb 2009, 14:34 -
FairUse Wizard indexing error
By PudyCat in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 12:26 -
How to Turn Off File Indexing in Vista
By SCDVD in forum ComputerReplies: 4Last Post: 13th Jul 2007, 05:09
