Hi all,
I normally don't post because I usually have no problem's to ask about, but, now I have an avi which has the following info from virtualdub and I want to encode it for vcd use in my standalone dvd player which is a samsung s221 and the region sticker on the back of the player has a number 1 on it,(I don't know if the 1 stand's for 23.976 or 29.97 or both).
Anyway, here is the info from virtualdub about the avi that I want to encode to play on my standalone player which I will be using 700mb-80 minute cd-r's (memorex 42x 700mb-80 min).
When I open the avi in virtualdub then I get the vbr audio stream detected message so I click OK, then I click on "FILE", "VIEW FILE INFO" and this is what I get:
Video Stream
Frame size, fps = 608x320, 25.000 fps, (4000)
Length = 150175 frames (1:40:07:00)
Decompressor = XviD MPEG-4 Codec
Number of key frames = 2009
Min/Avg/Max/Total key frame size = 2121/15862/47116 (31122K)
Min/Avg/Max/Total delta frame size = 106/3992/32684 (577693K)
Data Rate = 830 kbps (0.57% overhead)
Audio Stream
Sampling Rate = 44100Hz
Channels = 2 (Stereo)
Sample Precision = N/A
Compression = Fraunhofer IIS MPEG Layer-3 Codec
Layout = 229823 Chunks (0.01s preload)
Length = 96734749 Samples (1:40:03:89)
Min/Avg/Max/Total Frame Size = 104/420/626 (94468K)
Data Rate = 129 kbps (5.39% overhead)
Now, my question is:
With the above info, could someone please give me some help on converting this to ntsc either 23.976 or 29.97 fps (whichever gives the best result) for vcd use in my standalone player using the latest version of tmpgenc and besweet and virtualdub?
I consider my specialty to be PAL to NTSC conversions but this looks like an illegal download to me.Originally Posted by hawkei67
Prove otherwise and I might offer some help.
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03
