  1. NO idea why but when I run svcd2dvd with a source directory that contains VOBs [which contain svcd/mpeg2 output from ifoedit] the program terminates with errors. From two recent attempts I got the following in the 'send details to microsoft' popup
    AppName: 19ae60fd-bd23-4b8b-949b-0dfc9ede2d43.exe
    AppVer: 0.0.0.0 ModName: 19ae60fd-bd23-4b8b-949b-0dfc9ede2d43.exe
    ModVer: 0.0.0.0 Offset: 00004994
    AppName: 570b80de-93ae-4a23-907f-752817528ea8.exe
    AppVer: 0.0.0.0 ModName: 570b80de-93ae-4a23-907f-752817528ea8.exe
    this is what svcd2dvd log window says - it does create 2 16KB VTS files
    Starting SVCD2DVD: v1.5.1389.29929
    Begin time: 03:48:43
    -->Processing 0 mpeg files.
    ******** Creating DVD Folders...
    Creating VTS #1
    Creating VTS #2
    ============ Complete ============
    ============ Duration: 00:00:23.8042288
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    convert your vobs to mpgs. (even renameing them may work)
  3. Guest
    @ChrissyBoy
    thanks - renaming the VOBs to MPGs did the trick. I take it there is no way to use VOBs [as VOBs] as source if the VOBs contain SVCD compliant data thereby avoiding a lot of reencoding.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Not at the moment. I shall investigate the possibility.
    CB
  5. Originally Posted by ChrissyBoy
    CB
    well that's good enough for ;-|
    tbh I'm pretty new to SVCD & DVD compliant stuff - DivX is easy by comparison but it lacks the nice menus, chapters & standalone-playability
