Hello All,
When attempting to archive one of my DVD with ShrinkDVD 2.3 as well as 3.0 I get the following error:
DVD Shrink encountered an error & cannot continue.
CDvdCSS::Read Fail!
The reason is: Data error (cyclic redundancy check)
for what it worth I am running WinXP SP1 on a P4 2.20Ghz, 512 DDR Ram, 120GB HD (free), TDK 440n Burner & AnyDVD ver2.0.0.4.
Thanks in advance.
I once burned a CD-RW with some MP3 files and when I wanted to copy the files to another computer I was getting the same error message as you're getting. I used Nero CD Speed and DVDInfoPro to scan the CD and, there were lots of errors on it. I bet if you scan the media that you're trying to backup, you'll find errors on it.
Good idea. If it does not work, then try playing the main movie while trying to rip it.
Hello. -
7500man
if you have 2 DVD units try ripping the disc with the other device to the HDD. different brand DVD units might have different abilities in reading discs. had a problem reading a dvd with my NEC 1300a (could not rip 2 of 7 vobs with both Decrypter and Smartripper), yet my Lite-On rom had no problem. good luck. -
I kept getting an error message during the initial analysis (forgot what it was) when trying to rip a commercial DVD's with DVDShrink 2.3 last week. When I made the 5th attempt with DVDShrink 1.03 it worked.
What did it turn out to be? One big smudgy fingerprint on the DVD! :cD
Wiped it once with a disc cleaning cloth. Popped back in. Copied over no problems. :c)
Hope your solution is as easy as that. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 11:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
