I would just like to know exactly how these people capture these PDTV shows. I have been trying to capture the OC for the last few weeks. I have a ATI A-I-W 9700 card and I just cannot get it to go wide screen like that. So I guess I have 2 questions, do i have the correct card to capture something like that or do i need to buy something else. I have DTV and I am trying and would like to capture off of that. I do not have a TiVo reciever and i am not sure if i need one. And the second question is how do these people capture it, only because i would like to do it too.
Thanks all
TrueDis
How would i connect that to my DTV? Sorry Im an noob at this i have no idea if it can even be done. When i say DTV I mean DirecTV. I have cable but it is really bad quality. Also I dont know if this can be done but i believe that tivo takes the video directly from the stream and puts it onto a harddrive, if you could get the video off the harddrive would this accomplish the same thing (would be video quality be the same?)
TrueDis -
DirectTV doesn't support HDTV streams. DTV officially mean digital telvision, and refers to broadcasting only. Not Satallite feeds, or cable.
Would i get the same result from taking something that was recorded off of a tvio box? As in quality, or same result.
TrueDis -
TVIO only records what you can recieve. You can't revieve a PDTV signel so there is no way to record it. I don't think TVIO can take HDTV streams anyway. Its like 19 megabytes. TVIO re-encodes all video to its hard drive at D1 (480i, DVD resolution), I don't think it copies the stream as is, and HDTV is 1080i or 720p. HDTV streams are over a gigabyte per minute.
