HI,
I want to make movies which span multiple VCD discs. I have Pinnacle Express and it allows handling of only one disc full of files at a time. Is there any editing program available where I can create 2-3 hour movies, and then have them burn to VCDs one after the other instead of manually breaking down the movie to fit each disc?
Have you looked into the Guides or Tools yet?
https://www.videohelp.com/tools#VCD/SVCDAuthor
and Guides - just pick bottom bar and HOW TO AUTHOR VCD
lots to choose from. :c) Not positive what you want to do or what sources you are working with. I think most popular for VCD only is VCDEasy. Guides are listed below that may explain what's pssible with it.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Resizing videos and creating multiple DVDs in batch?
By DVD_Noob in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2010, 02:40 -
Creating video with sound from multiple images
By caio1985 in forum ffmpegX general discussionReplies: 1Last Post: 5th Aug 2010, 17:23 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
Creating movies in Pinnacle Studio 11
By kadavil in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2009, 14:38 -
Creating chapters from multiple video files in Sony DVD architect
By MTy in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 13:22
