Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Sorry if this has been asked before but I could not find a good answer
    in the forums...
    With respect to DVD encoding, at what bitrate cutoff would you choose
    to do a fast CBR encode rather than a VBR encode? In other words, if
    your bitrate calculator says to use a bitrate of XXXX Mbps, what
    value of XXXX is high enough for you to just CBR encode it
    instead of VBR encoding it? What would answer be if you used 9000Mbps
    as the max VBR bitrate? and for max 8000 Mbps VBR bitrate?
    Thanks,
    vcddude
  2. The highest value that will fit on the disc.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  3. Member vhelp's Avatar
    Mar 2001
    New York
    I would say, first encode a section that is of highest movements. Then,
    see how high the bitrate went up with that bitrate, using bitrate.exe
    Then, just ues that as your highest. However, if you want to go further
    in your math, you could factor in w/ the bitrate calculator, (assuming you
    are wanting to CBR your source)
    The way I see it is like this, IF you are ceroius about highest quality
    in your DV footage transfers, you want to match it, grain-for-grain, not
    macro-blocks to macro-blocks If I see grain in my footage, I want
    my footage to have that SAME grain. I don't want to see it "smoothed"
    out or pixelated or macro-block'ulated. And, only a final burn to CD/DVD
    and played on your TV, will you conclude w/ best judgements on your encodes.
    There are other techniques to better quality DV to DVD transfer or projects,
    but this is not the time here. You can have a look at a sample I did w/
    my TRV-22 at my VHELP's Sample clips... thread for an idea or approach towards better quality.
    -vhelp 2058
    Aug 2002
    I use 8000 mbit/s CBR and can fit one hour with WAV audio and good quality from DV to DVD-R. If the average bitrate is below 8000 then I set max to 8000 and use 2-pass VBR instead.
    Ronny
