I have made a VCD no problem, but my player can only play VCD 1.0, and I burned it using Nero which creates a VCD 2.0. Does anyone know of another software program I could use instead of Nero, or is there a way I change Nero so I can create a VCD 1.0??
It would be very unlikely that your player can only handle VCD1.0 or VCD1.1... What VCD player are you using?
The only program that can create VCD1.1 at the moment is VCDImager.
Regards.
Michael Tam
w: Morsels of Evidence
