OK here is my problem. I have some video files that use the Xvid codec and Ogg for audio, however despite the fact that they are avi files the extension is .ogg. I can play the file on my pc no trouble using an Ogg direct show filter, however I would like to convert to DVD so I can play on my tv. Using TMPEGenc I can encode to video but no audio! How can I extract the audio? Any ideas, i've tried to load into Virtualdub but with no sucess. Also how can I rename the extension .avi? I'm using XP any help much appreciated.
no help again......
I have the current same problem, i have a movie in .ogm format, have tried renaming the extension to .avi, then i try decompress using avi2vcd decompressor, but when i try loading the renamed .avi file into decompressor, the avi cannot be seen?
Come on peeps, help us out!!
TheDJ® -
Hi guys,
https://www.videohelp.com/forum/userguides/89139.php
I know this isn't exactly what you were looking for, but it may be a good starting point to encoding a .OGM to DVD.
As far as audio extraction goes, this should help:
https://www.videohelp.com/tools?tool=332#comments
It should (as far as I can see) allow VirtualDub to see and work with Ogg audio.
As usual, I don't know enough to provide The Definitive Answer. However, that magical search field located at the top of the forum helped loads!
Best of luck to you both!
CobraDMX -
The simplest way I have found to do this is:
1) Rename the file from .OGM to .AVI i.e film.ogm --> film.avi
2) Use a program called DeCompress (Its part of AVI2VCD), open the now named .avi file, select a destination location and click 'Decompress'.
3) The file that has been created can now be encoded for DVD using TMPGEnc.
(No idea why this method doesn't work for you TheDJ®)
This is the easiest way I have found anyway, there are other means but all involve demuxing the .OGG audio track and re-encoding it to something that is DVD compliant, saving the AVI file with no audio tracks, encoding this with TMPGEnc then remuxing the tracks with a DVD authoring program.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2357Last Post: 1st Aug 2025, 05:32 -
How to encode DV to .ogg?
By macphoto in forum ffmpegX general discussionReplies: 1Last Post: 30th Jan 2011, 04:33 -
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
Recode Xvid/Ogg to PS3 Suitable Format
By mcompton69 in forum Video ConversionReplies: 2Last Post: 4th Sep 2008, 07:51 -
Ogg Vorbis to xvid conversion
By mattr in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2008, 05:21
