Hi all,
I have been trying to convert avi's with MainConcept.
But so far every movies i have tryed the video freezes at roughtly 80% - 90%. The audio is fine.
Any ideas why this is happening ?
What other programs could i try ?
Need a lot more details. What kind of AVI's DV, Huffy, DiVX??? What are you converting them to? DVD, VCD, general MPEG for your computer?
You could try TMPEGEnc, but typically Main Concept will slog through about anything. My guess is you are converting some DiVX files. If so you'll probably need do do some repair work on the file. -
The avi's are xvid & divx. I have tryed converting to mpeg2, svcd & dvd but all have the same problem of freezing. The avi's are fine they play perfect. I want to convert them so's i can burn then to dvd's using TMPGEnc DVD Author.
I have TMPGEnc but its alot slower than MainConcept. -
I get the same problem when usinng Main Concept to convert Xvid/Divx files. It stops encoding about 80% into the file, the way I get round it is to use Virtual Dub to convert the Xvid/Divx file to Huffy and then use Main Concept. Also I am unable to frame serve to Main Concept but can to TMPEGenc, any ideas?
Should be able to frameseve to Main Concept just fine. Just use find all files when opening the file and then load the VDR.
There are several good repair tools under the tools section. I've used DivFix before and it works well. You'll probably find there are a lot of DiVX files that play ok, but don't encode well until fixed. Actually, ASF files are even worse. Actually, I found that the audio is the problem in most cases. I almost always just extract the wave file using VirtualDub then convert with 2lame or HeadAChe. Then use your encoder to just do the video and re-mux later. Poke around you'll find several good guides on how to do all of the above.
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 21:42 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 15:34 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 23:13
