[b]Forum for Drives and Boxes
What works and what doesn't????
Here is a partial list of boxes available.
http://newegg.com/app/listProduct.asp?DEPA=1&submit=Go&description=5%2E25%2Cenclosure
All the boxes work, it depends on what type of interface you need or want to use.
Available interfaces:
USB2.0
Firewire (IEEE 1394)
SCSI
What do you want to use the box for? -
I don't know what you're using this for, but if your loaning it out to friends then I would lean towards USB 2.0 which I think would be more common and would also work with USB 1.1. I would also go with an encloser that has the power supply built in so its basically using a generic power cord and USB cord.
Question: what's the speed limit on a burner if you hook it up to a 1.1 port? -
I would wait for the new box-standard to come out, more sides and greater openings.
I've noticed from the forums that dvd-rw's that work great as internal run into problems as external. ie: NEC will not burn -r in external enclosure. Pioneer and LG also ran into problems. Is it the box, or tech?
I have 2 drive bay settup and would like to buy dvd-rw as external since I would use it the least, IF box tech can handle it. More sides, lol good one Dog :P
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 12:32 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 18:33 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 12:45 -
Internal V External HDD for video editing work
By Rudyard in forum ComputerReplies: 11Last Post: 18th Apr 2008, 04:21 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 18:12
