Question:
I noticed as I authored dvd's for Tmpgnc dvd author, it starts the movie immediately. You must then click the menu option on the dvd player or remote control to select a chapter. How can this be done with DVD Lab? The authoring I've done with DVD Lab starts the dvd menu immediately.
Also, when I play commercial DVD's, they have an "intro" movie or maybe some commercials, i.e., "The Hulk" DVD. Is DVD Lab capable of producing the same effect?
Thanks, Pat.
In connections window right-click mouse and select "show button links" as well as "jump links". Change pointer from arrow to "+" to draw your desirable "first play" connection. That's all.
Have a look at DVD-lab's help file (connections). You 'll find exacty what you wish to do as examples.
P.S. In TMPGEnc DVD authoring tool you do it under "Display menu settings" (first play action). -
thanks, I will let you know how it turns out. How are your authoring dvd's using DVD Lab? It seems more flexable than Tmpgenc DVD Author.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
NTSC issue in DVD-Lab pro
By Ankin in forum SubtitleReplies: 2Last Post: 20th Aug 2010, 15:19 -
Help Authoring with DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 14th Dec 2008, 22:28 -
dvd-lab issue, needs to be solved desperately
By cL0N31 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 10:49 -
DVD Lab Pro - 2 cells issue
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 24th May 2007, 09:44
