Hi All,
Was just backing up a few of my DVDs when I realised that I forgot to authenticate BladeRunner Directors Cut in Apple DVD Player prior to using DVDBackup 1.3, however DVD Backup proceeded as per normal, ripped the DVD and decrypted with a key.
Although the DVD was a single layer & did not require DVD2ONEX, I ran it through it anyway as DTOX will not accept encrypted data, and it went through.
I tried it with a couple of other DVDs & the same happened - even with a different region DVD that DVD Player wanted a region change for.
I am running a G4 450 AGP with Panther, but could not replicate this on my 1GHz TiBook, also with Panther. This is a bummer as its the TiBook that I'd like to be able to do this with as I travel a lot & it would mean I would be able to rip discs from different regions. The G4's DVD-ROM has been flashed to RPC-1, the Powerbook has been updated to 2x, but no RPC-1 firmware.
Has this happened to anyone else?
Are you sure that at some point before backing up using DVDBackup in Pather on the desktop computer that you hadn't already played the disc? I think that the new DVD Player app in Panther not only remembers where you left off in a movie, but also remembers that disc's CSS key.
Originally Posted by AntnyMD
and what a nice feature it is, its like my dvd player with the automatic resume function even if you take the dvd out! -
Also I went on to format the HD & clean install Jag, then Panther, plus I chose a DVD that I hadn't watched in AGES. -
I'll look forward to independent verification on that, because that doesn't work in this corner of the planet.
Disc info prior to buying the discs
By lbeck in forum MediaReplies: 5Last Post: 30th Apr 2010, 00:10 -
Does law require DVD players to be sold as region specific to country ?
By Panchogun in forum DVD & Blu-ray PlayersReplies: 14Last Post: 28th Dec 2008, 07:47 -
can I download the version prior to 2.5 somewhere?
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 21st May 2008, 17:31 -
DVD recorder that doesn't require remote
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 13Last Post: 26th Nov 2007, 23:51 -
Do DVD resolution mpeg2 captures require to be encoded ?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 17:08
