What is AnyDVD?
AnyDVD is a filter driver that removes copy protection, region codes, user prohibitions and MacroVision from an inserted Video DVD on the fly!
AnyDVD allows the use of software dvd players or dvd copying programs like CloneDVD or DVD2one without the restrictions that normally come with the DVD format.
AnyDVD is developed by Elaborate Byte (Elby), the author of CloneCD and their newest toy CloneDVD to work hand in hand with it to backup DVD titles on the fly!
It doesnt matter if your DVD drive is region protected or not, AnyDVD works with any drive and any dvd!
Whats new in this version?
2.1.0.9, 2003 10 27
- New: Added option to start external programs on disc insertion of non-Video material
- New: Added option to start external programs if material has 60 Hz refresh rate (NTSC)
- New: Added option to start external programs if material has 50 Hz refresh rate (PAL)
- New: Added option to start external programs on disc removal
- The above options are useful to adjust the screen refresh rate to the inserted media contents
- New: Added utility "SetDisplayFrequency" to set and reset the refresh rate of your monitor or beamer
- External tools like MultiRes or PowerStrip can be used as well!
- New: Removed "Information" Menu Item, added "About" Tab in settings window
- New: If a DVD drive is added or removed, the drive selection list will display this change immediately
- Bugfix: After settings were changed, changes did not become effective before a media change
- Bugfix: AnyDVD accidently started a rescan, if non CD/DVD drives/volumes were added or removed (e.g., USB Sticks)
- Bugfix: If a DVD-ROM didn't had a drive letter assigned, the settings dialog could display a "Index out of bounds" error message!
- Bugfix: If AnyDVD was enabled, DVD-RAM was read only
- Removed ElbyCheck.exe from distribution
- Added Swedish language, updated many other languages
Results 1 to 1 of 1
AnyDVD or AnyDVD HD
By Tbag in forum ComputerReplies: 8Last Post: 17th Oct 2008, 22:08 -
anydvd 6.4.69
By shititin in forum DVD RippingReplies: 3Last Post: 16th Oct 2008, 18:12 -
AnyDVD & AnyDVD HD 6.1.8.4 final
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 11th Oct 2007, 21:27 -
AnyDVD & AnyDVD HD 6.1.6.6
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 30th Jul 2007, 16:07 -
AnyDvd or DvdRegionFree?
By Ramon in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2007, 14:39
