  1. If I backup a movie with DVD2ONE, can I use this backup to make another backup? If I can, what is the process? Do I use DVD Decrypter to put the movie files on my hard drive and then use DVD2ONE again to convert? Please help me on what will work. Thanks.
  2. Yes you can make a backup from a backup. Your original backup will be a DVD-5. This means that you don't have to use DVD2ONE to shrink it again. You can simply use DVD Decrypter to make an ISO image to your hard drive, then burn that image to another blank DVD. go here; https://www.videohelp.com/guides.php?howtoselect=6;30. Scroll down to the section DVD-5 to DVD-5 using DVD Decrypter for instructions.
  3. Thanks, I'll try that.
