not a videophile at all, but i'm attempting to burn a movie i downloaded into a single disc VCD with Nero 6.0.0.19. the file is MPEG...right-clicking on the filename within windows media player:
Video codec: ffdshow MPEG-4 Video Decoder
this is supposedly 700MB (but Nero says it's 734MB which confuses me) and i'm thinking that should fit onto 1 CD with the help of a bit of overburn. BUT this is where i'm stuck. when i drag and drop the movie in Nero and start the burn (simulation so far), it'll bring up this new window where it's "encoding video" and i notice in the top right it reports the size as now being 864MB 98:18.19. now how come the size grew so large? is it due to it being encoded into VCD format? how can i keep it under 800MB so i can fit it onto 1 CD? would using a different encoding program like TMPGENC solve my problem?
Results 1 to 16 of 16
so i guess i have no way around this 1-disc VCD eh? i just didn't want to have to go thru the trouble of splitting a movie. does anyone recommend a movie splitter program?
Research kvcd . It's not 100% compatable with most players, but you can get more on a disk that pure VCD.
I would also suggest you look at DVD2SVCD. If your player supports SVCD, you will be much happier than working in VCDs. The program requires an encoder, but TMPGEnc has a 30 day free trial. It's fairly simple to use, but you have the ability to get very complex with a little effort.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
yes, sorry it is indeed an avi file. so does that in any way allow me to burn the movie to 1 CD?
RIGHT SO IF ITS AN AVI FILE, DO U WANT TO BE ABLE TO WATCH IT ON A STAND ALONE DVD PLAYER OR JUST BACK IT UP TO A CD? WHATS UR EXPERIENCE OF MAKING S(VCD)S THERES A FEW ROUTES U CAN TAKE?
as per the properties in windows media player, the audio codec is:
MPEG Layer-3 Decoder
yes, i want to be able to watch it on my DVD player. so far the only experience i have is burning 1 other movie in Nero without any problem since it already came split into 2 parts (total size was about 950MB), so i just used 2 CDs. this current movie i'm dealing with is the first one that isn't split up. will doing what MOVIEGEEK suggested help me get under that 780MB limit? and i am using 80min CD-Rs. -
Check out this guide:
https://www.videohelp.com/forum/userguides/84759.php
and just skip the Clad stuff (since you already have a *.avi), start with TMPGEnc and chose the .avi file for the source in TMPGEnc.
I have made many xVCD's with this guide, just be sure your player will support them.
-D -
ok thx i'll give it a try. got my fingers crossed. and thx for all your patience with this noob
i followed that guide and i got the movie to fit onto just 1 CD, but when i play it in my DVD player i notice the subtitles are barely visible at the bottom. they're half cut off. and i also notice movie seems like it's been squished on each side...ie. the people are stretched/thinned out (i think that's called the aspect ratio?). maybe that was due to fitting all that data onto 1 disc? the guide said to start off using Constant bitrate with 900 bitrate which is what i had set TMPGEnc to, but it also said for better quality one can also encode with 2-pass VBR with 1150 bitrate. would that solve the problem so i can see the subtitles? thanks.
You have a display aspect ratio problem, it has nothing to do with squishing too much data on the disk. I like your thinking though..
In TMPGEnc you need to select Full Screen (keep aspect ratio) in the video arrange method box."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Most DVD players that "support" VCD don't actually support all the specs of VCD - hence even if you do the correct aspect ration and everything, due to the properties of the TV, the bottomw witll tend to be cut off. I ususally use center (custom size) for video arrange method and tweak the settings and encode and burn a test clip to see how well the aspect ratio looks on the TV and how much gets cropped off until I'm happy. If it messes up the actual display on your comuter, just watch it in Zoom player where you can adjust video pane size, aspect ratio, etc.
but i'm wondering if the different aspect ratios in the Video and Advanced tabs would be causing the problem? should i set both to 4:3 525 line (NTSC)? and the Video arrange method to "Full screen" or "Full screen (keep aspect ratio)"? i'm not sure what the difference is.
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 14:22 -
Burning DVDs trouble
By ssaamm in forum Newbie / General discussionsReplies: 8Last Post: 4th Aug 2009, 05:24 -
Is anybody having trouble burning semi-pro?
By mikes01 in forum DVD RippingReplies: 3Last Post: 12th Jun 2008, 19:18 -
Nero burning trouble with logs.
By bufalo in forum Authoring (DVD)Replies: 4Last Post: 13th Jan 2008, 07:43 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 16:10
