Hi
I have downloaded a Movie called Dinosaur.
I have tried to use a number of AVI coversion programs including TMPGEc to encode it to MPEG. I keep getting an error message saying "Can Not Open or Unsupported!
This movie plays with sound on Windows Media player and DivX Player. I ahve about 5 other movies that are the same.
A log of the Movie (Video) is as follows!
Dinosaur (DVD) (DivX).avi
File Format: AVI, Windows Audio Video Interleaved
File Size: 712620 KB
Video Info:
Video Supported: False
Video Format: (Div 3) Unknown Codec
Video Length: (Frames). 110329
Video Length: (Seconds). 4602
Video Frames/Seconds: FPS: 24
Video Resolution: 640 x 352
Audio Info:
No Audio Stream
Apart from deleting the movies I have tried all I know.
Is there anyone who can help????![]()
Blah, look at my last post. Re-explaining 50 times is my monthly limit.
The codec is DivX 3. You don't have a valid codec installed to display it. Change the 4cc to read divx/divx and make sure you have ffdshow installed. You can then convert the video in TMPGEnc with no issues. Audio is probably AC3, follow the guides on it's conversion (and you need the codec).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Hi
Thanks for help!
Not sure where to find and change 4cc but will have a go
Eric
MPEG4 subtitles
By miconba in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 01:11 -
BeLight - unknown error
By TA_Kosice in forum AudioReplies: 0Last Post: 16th Sep 2010, 14:08 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 20:25 -
unknown file
By nicgrosso in forum ffmpegX general discussionReplies: 27Last Post: 7th Apr 2008, 15:20 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 11:02
Hi
