Can someone please help, I recently bought a JVC DVD player (XV-N33SL) it says in the manual it can play DVD VIDEO, DVD-R (Video format), DVD-RW (Video format) +RW (Video format), SVCD, Video CD, Audio CD etc etc. But when I try and copy a DVD to a DVD+RW it says 'no disc' when I insert the disk and ejects it straight away. The method I use is
- DVD decryptor to decrpyt the files to my hard drive
- Then instant copy with hard drive in the left column and my DVD burner in the right column
The discs that I am using are Phillips
Is there something wrong with this method, or are the discs not any good,
Thanks in advance
Mike
Originally Posted by mikewill53
make sure the dvd files you are burning are in the VIDEO_TS folder. also you may want to make a AUDIO_TS folder.
1. Try playing the on your PC with PowerDVD or some other software dvd player. This should verify the disc contents (such as the VIDEO_TS directory).
2. Try playing the dvd in ifoedit (load the VIDEO_TS.IFO). I have noticed that when sometimes certain titles are missing, or the dvd navigation information is somehow invalid, ifoedit does a good job of telling you (unlike PowerDVD). If ifoedit plays the dvd without complaining, chances are it will play without problems in a dvd player. -
How many Gigs did you put on your DVD+RW. Sometimes, you need a minimum capacity for the player to recognize the disk.
My Malata needs at least 3GB to be able to recognize a DVD-RW. When I have too small a file, I put other files in the AUDIO_TS directory up to the required capacity.
Try to do the same with, say, 4GB of data and chwck if it works. -
Thanks for everyones help, in the end I took the dvd copier back and swopped it for a different one. The one I had couldnt copy DVD-R or DVD-RW I didnt think it would make a differnece when copying a DVD to a DVD+RW but apparently it did.
Mike
Edited DVD won't play on standalone 1yr old DVD player.
By Brooke2424 in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2009, 13:50 -
Burned Video DVD Won't Play in Standalone Players
By adamwolf1965 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2009, 21:21 -
Media center video won't play on standalone dvd player
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2008, 22:04 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
