Hi there is it possible to convert a VCD to SVCD?
YESOriginally Posted by gotenks20036
My turn to ask a question.
Why attempt this futility?
Well since you have only been a member for 3 days, I will give you this advice. Doing this would be an utter waste of time for 2 reasons and you will see why with experience.
1. Quality would be reduced in the re-encoding process.
2. You will need more CD's to fit the same file.
There is absolutely no reason to do this. -
...unless his player refuses to play VCD, but plays SVCD fine?
/Mats -
You will make the quailty worse, not better.
The only reason to do it is you stand alone player doesn't support VCD, jsut SVCD.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Yeah, but has anyone heard of a player that supports SVCD and not VCD? I mean half the ones that say they support SVCD don't really, and most do support VCD, often times even if they don't say they do, as long as they can read a CD.
Guessing that maybe what you are really asking about is just converting to MPEG II, the question would still come back to why? To make VCDs compatible with DVD media all you have to do is convert the audio, not the video. If you really, really need MPEG II for some reason you can do that, but I wouldn't advise changing the frame size.
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 03:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
