I have spoken to toshiba this morning regarding VCD that I cannot play on my dvd player (movies from DV camera, encoded for VCD through Toast 6 and EasyDVD) Toshiba states that they movie files should be 'minus' in format, I have never heard of this for VCD only for DVD at that is for the media and not the file type.
Any comments would be much appreciated.
Satman68
Sounds like the person from Toshiba did not know what they were talking about.
Sure, minus format, of course, sounds great.
I did phone Toshiba and they state it should play VCD's, so they have provided me with a replacement. Which appears to be slightly worse ie. I could play DVD+RW discs with the first player (which also didn't have the PBC menu) but not VCD. Now I can play VCD's (picture skips though) but not DVD+RW and some commerical DVD's!! They are collecting this one and replacing again. They state VCD's MAY work depending which software and DVD burner/ CD burner you have. They didn't tell me which equipment, software I should have though. Dam!
Satman68 -
I had a Toshiba sd210 and it would play vcd no problem. I never tested it with "home burn" DVD discs tho. It also played svcd (slight sound lag). VCD burnt with vcdeasy. encoded with tmpgenc. tested out using phillips ricoh or verbatim cdrw or use infiniti cdr, these brands worked in my tosh. You got a replacement out of them? when I asked about svcd problem they were less than helpful.
The electronic components of the power part adopted a lot of Rubycons.
track 3 = track 1 minus track 2 ??
By tigermann74 in forum AudioReplies: 6Last Post: 31st Mar 2011, 04:29 -
What does it mean when subs have a minus before the text?
By DVMaster in forum SubtitleReplies: 2Last Post: 29th Jan 2010, 00:56 -
Are DVD-R/DL (double layer MINUS R) incompatible with ISO/MDS for +R/DL?
By miamicanes in forum DVD RippingReplies: 16Last Post: 31st Dec 2009, 21:24 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 08:59 -
DVD: Minus or Plus?
By markannab in forum Authoring (DVD)Replies: 14Last Post: 29th Jun 2007, 20:14
