Does anyone have a good resource for finding out if a given commercial disc is single or dual layer?
(short of checking them all myself?)
Most of the retailers are hit or miss; they don't know if the back of the box doesn't say...
thanks.
checking only takes seconds. Just seach google with the movie title, and the keyword 'layer'
Example: Die Another Day Layer
You'll get a few hits with the layer density of the disc. The best info is usually under the DVD review type links. You'll find almost every new disk is dual layer. They do it to keep you from easily copying the disc.Impossible to see the future is. The Dark Side clouds everything...
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 10:48 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
