Recently I have been seeing lots of inexpensive dual format dvd burners, mostly generic, such as bti or highquality or some really generic sounding name. I have also been seeing a dual format polaroid dvd burner for 130 or so.
Are these dvd burners safe to buy? What is wrong with them, will they just be unreliable or are they just cheap because they are generic
Results 1 to 9 of 9
Originally Posted by awdark
Sony, NEC, Optorite/Sanyo, Pioneer, LG/Hitachi (HLDS), Plextor, Lite-On, and BTC
While there may be other manufacturers not mentioned here, most other brands of dual format DVD burners are based on the OEM models of the above list. Most name brands use the more reputable manufacturers such as NEC, Pioneer as their OEM drives, while no name brands tend to use BTC as their OEM drives. If there is anything negative regarding those no name brands, it'll probably be the lack of tech support and firmware upgrade, not necessarily the burner itself.
Since the price of all brands of dual format burners has dropped significantly, it's much better to get a Pioneer or NEC bare drive for less than $140 from on-line vendors than to buy a no name brand without knowing what drive inside. Just my two cents. -
why should I buy online with that hassle when I can buy at Frys for $129, have 30 days to try it out, a simple return and no hassle if I don't like or better yet get it at sams club with their 6 month return policy, no hassle and no shipping cost!!
Jim -
You can take a burner back after 5 months to Sams? -
Originally Posted by thxkidWant my help? Ask here! (not via PM!)
Top right corner of the main page always has daily prices on these things. Just click on them you're set.
NEC 1300a for $119.47 delivered. Worked like a champ. Only coasters come from newest DVDDecryptor, which doesn't do buffer underrun correctly ( I can encode and read email while burning at 4.2x with Nero 6.0.19, but if I bring something off the taskbar, DVDDecryptor gives me hard errors and stops).
The best part about dual format, is you can buy what's on sale. Lately it's been Ritek G04 4x -R media for $1.20 each
And, once you burn at 4x, you can't go back to 2x or <groan> 1xTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ok.. So it sounds like these burners are okay overall, but buying online would give you a name brand one at the same price.
I think I will wait for the price of the name brand ones to drop in stores. Consider me paranoid about the internet still
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 18:27 -
Req help choosing inexpensive multi-region DVD player
By Golem in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Feb 2010, 13:13 -
What camcorders are best, inexpensive for making Instructional DVD's?
By scenicworld in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2008, 07:29 -
Wanted: inexpensive DVD Recorder/VHS Combo unit that is reliable
By Kmical in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Feb 2008, 10:57 -
Pls suggest a good inexpensive DVD burner
By phildis in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Nov 2007, 11:29
