I dont know if this has been seen before but im trying to encode a dv file to an .avi file. Doesnt matter which XviD, mpeg4, or divx 3. Anyways when i do it to mpeg1 or vcd mpeg1 it works fine and encodes the whole file but when i choose one of the .avi settings it only encodes about 9-10 minutes of the total 22 min file. It acts like its finished and everything but when i open the file to watch low and behold its only about half there. Thanks.
Results 1 to 10 of 10
I have the same kind of problem with .dv material, but they are a little bit different;
I use a A/D-converter (Formac Studio) and record it with iMovie, cut the commercials out and export it as a medium quality 720*576 PAL DV stream with 48 kHz to an external Lacie d2 FireWire-harddrive; it is then one .dv file with 15-20 GB; then I try to encode it in ffmpegX 0.0.9a to an .avi.
The settings are as following: mp3 audio with 192 kBits VBR, recorded as one 1,2 GB avi file with 2000 kBits video bitrate, and cropping as following: 704 434 8 70; in the video settings I take as video parameters 704*434, Unknown and PAL 25 images/sec frequency.
When I use the ffmpeg codec, it starts encoding and i get the following message: <dimensions are out of range, remember to scale first and then crop second>; i use the deinterlace filter with two-pass, high quality, B-Frames and and 4 motion vectors.
When I use the mencoder codec, it starts encoding and stops after 9min 55 sec of the movie processed without any warnings; I use all filters available and two-pass with all other options activated.
I still can encode it with ffmpeg without cropping, but I would like to take advantages of the better filters of mencoder, so if someone could give me an advice, I would be very, very happy to really start using my Mac the real way.
The ffmpeg codec uses for now different crop values. They must be entered in TBLR (top, bottom, left, right) format, so you need to calculate this manually for now (this will be automatic in later versions). The mencoder crop values are not in TBLR format but width-height-x,y origin.Originally Posted by Arnaut
Thanks for the quick help, major, but it creates another problem:
when I Use a 720*576 DV file, and want to cut the black bars, I use 704*336 with 120 120 8 8 and I get a 4:3 avi file with eggheads using ffmpeg; when I use mencoder with 704 436 8 120, i get the scaling/cropping that I want, but it stops encoding after 9 min 55 sec.
Am I doing something wrong with the ffmpeg cropping , or is there another problem??
Guesti have tried the same thing and have the same 4:3 output.Originally Posted by Arnaut
need to encode to 528x224 from 704:320:8:128 mpeg2 file with separate audio file.
thanks for help
It is very important, that you do NOT choose the "Full Quality DV" Setting when exporting from iMovie. This just makes iMovie glueing the 2GB chunks together in which it records movies. Mencoder can't handle that.
Here's what to do:
Choose "Expert settings". Click "Export". Choose "Movie to Quicktime Movie". Click "Options". In "Video Settings" choose "DV PAL" (or NTSC, if you are on that TV System).
In the Audio settings, choose uncompressed 48khz Stereo. Uncheck "Prepare for Internet streaming". Make sure the output file has .mov as extender.
Now the recording is reencoded as a single movie which Mencoder will encode completely as AVI.
encoding closed captions in an .avi file
By jbaber in forum Capturing and VCRReplies: 9Last Post: 13th Nov 2010, 10:45 -
Encoding avi file
By chikchik in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2009, 23:21 -
No file after encoding (No output file specified)
By Bizbo in forum ffmpegX general discussionReplies: 1Last Post: 25th Jul 2009, 05:17 -
Huge AVI file after mencoder encoding
By nickman00 in forum DVD RippingReplies: 3Last Post: 2nd Jun 2009, 19:57 -
help - re encoding an avi file
By shadoxity in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2008, 05:05
