I just installed a new Pioneer 106 burner in my # 2 computer. The burner worked fine except when attempting a backup of DVD movies using DVD X Copy Express V 2.5.4. I kept getting an error trying to rip the movie. The error was "Error occurred reading sectors". I attempted to rip the movie in my # 1 computer which has the Sony DRU 500 and it worked fine. So the disk was good. I looked through the 321 Studios forums and dvdrhelp forums using keywords including Pioneer 106 and the error I was getting. I found no topics with a fix for my problem. I figured I should see if the movie would play in the # 2 computer then realized I had not yet installed Power DVD software on that machine. I installed Power DVD on # 2 machine then tried to view the movie. It viewed just fine. I then went back into X Copy Express for another backup attempt and it worked great. I assume it was installing Power DVD that fixed the problem. I'm posting this message just in case some other poor soul has the same problem and looks it up.
You must update your Poineer 106 firmware.
The latest firmware avalible at
http://www.pioneer-eur.com/eur/support_software.jsp?category=support/software
After updating your firmware that error message "Error occurred reading sectors" will go and you can burn easly
I really advise you also to update your virsion of DVDXCOPYExpress V 2.5.4 to V 3.0.5. Check with 312 studio for latest update. -
sometimes you have to unlock a dvd first, you do that buy playing it for a moment.
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
Sectors Error While Burning
By rckowal in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 08:19 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 14:15
