I just encoded my first .AVI movie using TMPGenc and the resulting .m2v file turned out to be 5.2 GB and then I also have the audio as a .wav file at about 1 GB that I'll all need to burn onto a DVD+R disc. I'm assuming I need to do the video over again and try and get it to a smaller size? Correct? Any ideas on how to get it smaller.
compress your audio to mpeg audio or ac3 first off ..
re-encode your video file would be one method to reduce size ..
or go ahead and make your dvd project and use dvdshrink on the VIDEO_TS folder you made (before burning it) on your hard drive .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the suggestions. I'll change my audio to MP3 and see what that does.
Is there a way to tell how big your video file will be once you encode it before you actually do it? -
you want mp2, not mp3, if you want it to play in a standalone.Originally Posted by Touchdown
Go ahead and author your existing oversized .m2v file and ignore the warning that it won't fit on one DVD. Then use DVDshrink to reduce it to a size that will fit on one DVD.
This will reduce the bitrate somewhat but that's going to happen anyway if you "go back to the drawing board". 8)
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
