I want to capture video but my 9200 does not have a video-in. What are my best options? Should I keep the 9200 and buy a separate pci capture card?
Well i would say dazzle 2 go to www.dazzlegeek.com to see if it will work with your mother board. http://www.shopharmony.com/ Dazzle 2 is better then ATI for Satellite capture's ATI AIW are better for VHS capture's to get a ATI AIW go to www.pricewatch.com
I am skeptical of Dazzle 2 because of the reviews. And according to the reviews the ASUS TV Tuner card seems like a great card. But I'm not sure if it is compatible with my Radeon 9200?
Should I Upgrade Capture Device?
By hanoihancock in forum Capturing and VCRReplies: 13Last Post: 13th Apr 2012, 12:44 -
2nd best option to capture video to computer from Camcorder??
By Canes in forum Capturing and VCRReplies: 15Last Post: 10th Jun 2010, 07:17 -
Capture Card Upgrade
By wcwman28 in forum Capturing and VCRReplies: 13Last Post: 27th Oct 2008, 21:22 -
Capture problems, PAL60 option
By CoronaStar in forum Capturing and VCRReplies: 1Last Post: 11th Oct 2008, 08:38 -
How do i play XVID and DIVX files with my Vid-out (Radeon 9200) on my TV
By azman666 in forum Software PlayingReplies: 2Last Post: 13th Jun 2007, 23:09
