I have roxio 6
I have Nero
Is it poss. to fit more than one backup of a movie on one dvdr. Like using a header trick for vcd's. ? I did the search thing and didnt find any topics ..so here i am asking.
Just trying to drop them in the svcd setting on roxio using the dvdr seems like it is wasting a lot of space ..after all the files are only 700 mb each.
Mr knocker looks like I will have to do some more software purchases
before I can do that.
It does look good ..... I just thought I might be able to use what I have. It took me a week to get all the setting just right when first learnng the dvd to svcd back up with out any issues. I have a large mpeg collectio of my dvd's on hard drive maybe if I get the command file and then place the mpegs in the as data it will be able to play on my stand alone dvdplayer
and I can use all 4.7 gigs of space ? I just dont wont to go wasting all my media goofing around I am cheap.... ha ha ok frugal.
Thanks -
Don't buy anything yet. Download the software, and use it for the trial period and then decide if it is right for you. That is why the companies offer trial ware for free for a short time.
Hello.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Ripping a DVD, editing it, then putting it back onto a new DVD. HELP!
By CaptainZissou in forum MacReplies: 11Last Post: 6th Feb 2010, 23:18 -
Software to play back AVCHD-DVDR
By cheerful in forum Software PlayingReplies: 5Last Post: 17th Nov 2009, 23:14 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Maximum Length on a single layer DVDr
By acid_burn in forum Newbie / General discussionsReplies: 6Last Post: 16th Dec 2007, 05:05
