just wondering if it's possible to change/add to the wizard ie i'd like to add a VCD(PAL) category that (a) shows up with CBR of 2000 and time/700 or 800mb. also (b) can i change the default bitrate setting, particularly the motion search precision setting so's i don't need to go in there every time and change it manually?
From the main program window, select Load and your template you would like to alter. Alter all the settings you want, then select Ok until you are back to the main window again. Select Save. You must rename the file here, or you will have to reinstall TMPGEnc to get your default template back. Once the template is saved under your new file name, it should be available in the wizard the next time you run it under the name you gave it.
Hello. -
I found that it doesn't save all of the settings that you make. You'll still have to change some manually.
"Art is making something out of nothing and selling it." - Frank Zappa -
thanx for the replies - i do as you suggest, but nothing extra appears in the wizard. the saved template is in the template folder of tmpenc, but it just aint appearing...any more clues?
When you renamed it did you keep the extension .mcf ?
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44 -
Registration Wizard
By Brainfire in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2007, 13:53
