Hello,
I have just made my first DVD out of a AVI with subtitle and all that. It worked out fine exept for the fact that the CCE logo is interferring with the subtitle.
I followed the guide http://www.doom9.org/index.html?/mpg/avi2dvdr.htm
I am fully aware of that I need to by CCE to get rid of the logo, but isn' t there any way to move it, for example to the upper part of the screen instead?
Or, if that is not possble, is there any way to move the subtitle to the upper part of the screen instead?
I´m using Subtitle Workshop (*.srt files) to "edit" my subtiles.
I hope someone can help me.
You must be burning the subtitles into the video. Since CCE is in "control", it will put in its logo last (and over your subs, since it thinks that your subs are video).
Put your subtitles in a subtitle substream, and select them (or set them to always be on) in your authoring tool.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Since I´m a complete newbie at this, your solution is complete mumbojumbo for me. Could you please explain where (in the steps in the guide I used) and how I can slove this.
Many Thanks.
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 21:52 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 12:10 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
