I am having a problem with WMP.
I can't get audio. I have uninstalled Real Player, Quick Time. I uninstalled WMP and did a reinstall and everything works but the audio.
I am pulling my hair out ....... both of them.
Oh, I did check the mute button. :>)
Any suggestions.
Audioa t all? Of specific Audio. AC3 is not natively supported. Will it play Audio CD's and/or MP3's?
Sounds stupid: Did you actually plug the speakers in the correct hole? Does the Line out work in your stereo? Does device manager show a yellow exclamation point?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the reply.Originally Posted by Gazorgan
Yes, the sound on the machine works. Real player works fine. I also am using a audio editing tool, Cool Edit Pro, it works fine, CD player works, WMP plays perfectly, but there's no audio.
I've uninstalled and reinstalled both Real and WMP as well as dumping completely Quick Time. But still WMP audio won't work. I've tried unselecting all meia associations in rean and associating all media types in WMP, still no audio.
WMP worked when I first got the machine. But in adding other software and such, somehwere along the way I've lost audio on just the WMP.
Frustrating!! -
You can try this. Re-install your operating system just to repair the OS. Sometimes during the un-install procedure it removes some of the dll's in your system. Repairing your OS will put put back the original dll's on your system.
Will I need to back up files such as word or will the re-install not effect saved files?Originally Posted by bebe
Repairing the OS will not affect any files on your hard drive. It will only put the original installation files on the system.
display size between windows media player and VLC player
By kool_k in forum Software PlayingReplies: 4Last Post: 6th Aug 2011, 16:18 -
Windows 7 Media Center to use Windows Media Player for MKV
By pvong in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2010, 11:26 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 11:01 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 00:18
