I am trying to clean up audio that has been distorted. I have a highly compressed divx movie with a high, tinny sound in the background. I was going to use Goldwave and try to remove most of it but was wondering if anyone knew the best combination of filters or of another way to fix the audio. Thanks.
Hi I use gold wave and just select Volume > Maximise
Your problem might be diffrent to everyone elses, cut most of the audio away and save a little wav file, so that you can experement. When you are happy with the results, load the avi back in any use the same filters again.
Noise reduction is always a good filter, but maybe not for your problem....
Cleaning Up Audio
By Yeah in forum AudioReplies: 2Last Post: 9th Apr 2010, 23:41 -
Cleaning Up Audio On A DVD-R
By spliffy in forum AudioReplies: 0Last Post: 17th Apr 2008, 19:55 -
cleaning up audio buzz?
By spiritgumm in forum AudioReplies: 1Last Post: 15th Apr 2008, 19:43 -
I need some help cleaning up Audio.
By efb91 in forum AudioReplies: 1Last Post: 22nd Sep 2007, 13:28 -
divx multi passes and filters
By mtamimi in forum Newbie / General discussionsReplies: 11Last Post: 19th May 2007, 03:51
