What authoring software is available that will make a DVD-9 ? I know Scenarist will do it, but it seems too diificult to learn and it's WAY too expensive.
I don't care about fancy menus or encoding feature, I just want to be able to put 140 minutes of video and my AC-3 surround files on one DVD.
And, by the way, the client wants to replicate 1000 discs. I am planning on buying a DLT tape drive for submitting the files to the replicating house...
Will Sonic DVD Producer or ReelDVD do it?
I went to Sonic's site and it said this about DVD Producer:
DVD Producer can make Dual layer projects with a DVD-5 Video zone.
However, it’s not currently possible to make a Dual Layer DVD-Video. It is possible to premaster a DVD-5 Video zone with up to 4GB of ROM data making a Dual Layer DVD Hybrid title (DVD-Video and DVD-ROM on the same DVD). This is done using a combination of DVD Producer and Sonic ROM Formatter (which is included with every purchase of DVD Producer)
What does this mean ? What is a "layer break" and what is a "DVD-5 video zone"
Closed Thread
Hey there Draggonsf -
You know, you may be right. And I hope you are right - that I can use a DVD-5.
Here is the situation. The source video material was shot by a local Catholic TV station. A live concert that they used three cameras and editted it with "Video Tooaster". They have given me the MPEG2 files that are encoded at an average bitrate of about 7. (I checked with Bitrate viewer.) They give me individual segments of the video on CD-ROMs.
I am thinking that they could go back and re-encode at about "3" and we would be able to fit everything on the DVD-5.
By the way , my job is to mix the 5.1 surround audio, author the DVD, and prepare it for the replication house.
I see your problem.You have to join all those mpegs and mux them with your AC3 audio.
And your problem is, all standard DVD Authoring programs can handle only file < 4.7 GB.Maybe DVDShrink is an option fro reducing the size (don't know if it's possible)
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
DVD Authoring Software
By Toxic1 in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2010, 02:39 -
By rancineb in forum Authoring (DVD)Replies: 8Last Post: 9th Jul 2008, 14:11 -
Best DVD authoring software?
By skybadger in forum Authoring (DVD)Replies: 8Last Post: 16th Aug 2007, 05:11
