    Mar 2002
    Kirkland, WA
    I just replaced my VeloCD Rewriter with a NEC ND-1300A DVD +/-R/W drive. Of course, the InCD packet writing software I was using doesn't work with this drive, and it doesn't look like newer versions will, either. I depend on being able to use CD-RWs as extra large floppies to cart solid model files to and from work. Is there anything I can use? Or will I have to add the VeloCD back into my system?
    Thanks,
    Tim
    Dec 2002
    Costa Rica
    InCD will work but you will need a Nero license that supports your burner.
    Mar 2002
    Kirkland, WA
    I downloaded Nero 5.10.54 and it recognizes the ND-1300A just fine. However, it looks like I'm going to have to load the same version of Nero on my work computer in order to use the discs as a floppy from both ends.
    Thanks,
    Tim
