I am using DVD Architect to create a DVD of many small clips of family videos. I am inserting video clips one by one onto my menu, but when the DVD plays and the user selects clip1, after finishing clip1 I want it to automatically play clip2 and then clip3 and so on. Ulead's DVDWS has this feature with it's 'Next Title' and 'Last Menu' option for a clip. How can I do this in DVDA? I don't want my users to have to click a video clip...watch it....then to be dropped back to the menu and then have to click on another video clip. I tried to create a music compilation and used video clips instead of audio as the online help recommends, but this kinda stinks and does not look very good. Any help appreciated. Thanks.
DVDA does not currently have end actions which would let you do what you want. You can string together all the clips into one avi or mpeg stream and then set chapter points in DVDA - selecting one chapter would then continue after that chapter instead of returning to the menu. End actions has to be one of the top requested features for the next version.
You also might want to check out DVD Lab. I haven't tried it in a while but I think it does have end actions, gets good reviews and is not that expensive. I don't think it can encode though so you need to import already encoded streams."As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Sony DVP-NC665P - Cannot Play DVD's Consecutively Automatically
By searchlight in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2011, 01:21 -
Default Chapter title - DVD Architect 5.0
By KayAt in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 05:11 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
DVD - How do I make all files play automatically?
By gina_here in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:25 -
Sony DVD-Architect: Title advance (skip) in playlist faulty?
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 28th May 2007, 14:07
