DTS is digital output right? will DTS 6ch still work in a dvd player that is not using digital ouput (optical or digital coax)?
if it has a built in decoder for DTS yes .
The short answer ... most likely NOT.Originally Posted by denz_ngr
Some DVD players (but very few) will downmix the DTS into normal 2 channel stereo sound that you can output through the regular LEFT(WHITE)/RIGHT(RED) RCA STEREO jacks.
My Cyberhome CH-DVD 500 does this.
But like I said very few stand alone DVD players do this which is why all DTS DVD discs also have AC-3 audio as a back-up for those that don't have DTS capabilities since the official DVD spec does not REQUIRE DTS support.
It probably should be pointed out too that, if you do have a DVD player that downmixes the DTS signal... that's exactly what it's doing, downmixing from 6 channels to 2 channels. So even though you're hearing sound, it's no longer DTS.
some dvd players have discreet 6 channel analog outputs .. and can decode ac3 and dts and then spit it out ...
thats what i meant above"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
That's correct I forgot about that but I assume if the person who originated this thread didn't have a receiver with digital inputs they didn't have a receiver with 6 channel inputs.Originally Posted by BJ_M
What you know what they say when you assume something ...
I have a Player with 6 analog outputs. (StarMedia) AC3 and DTS
I use an Onkyo Reciever for Front L/R and Back L/R
An old HiFi Amp for the center Box and and a
Powered Subwoofer.
Works a treat and although I didn't expect much for the cheap price the onboard 6 channel preamps are excellent !
MP4/AAC -> XVid/AC3 6ch
By brugi in forum Newbie / General discussionsReplies: 16Last Post: 20th Aug 2014, 22:43 -
6CH DTS Channel Order?
By maxeemo in forum AudioReplies: 4Last Post: 14th Apr 2011, 17:58 -
AC3 6ch audio strange behavior in AVISynth
By lovyagin in forum Video ConversionReplies: 10Last Post: 1st Mar 2010, 11:17 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12
