I get nothing but errors no matter what format or codec the video is that I'm trying to encode in TMPGenc lately.
I even uninstalled and reinstalled newest version, some problem. I must be missing something. I get the error "File xxx can not open, or unsupported."
I checked codecs, but they are there. What am I missing? Is there something comparable that might work instead?
When I got that error message it turned out that the avi I was using was of the wrong type. I believe there are avi 1 and avi 2. I found a free converter in the tool section and after conversion all worked fine.
Codecs Description Type/$ Rating Comments
Canopus DV File Converter
If you can't import, open or play DV video in a tool try convert to DV type 2 or Canopus DV(no quality loss).
DV Type 1 to DV Type 2 Converter
If you can't import, open or play DV-video in a tool try convert the type1 DV to type 2 DV (no quality loss). -
Check my sig, second link.
Capture problem grr
By Digitalexp in forum Capturing and VCRReplies: 6Last Post: 27th Mar 2012, 17:48 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
