I apologize if this has been covered somewhere, I searched before posting but haven't found anything conclusive.
Does anyone have problems with NTSC 24p mpeg2 and DVD SP? ffmpegX mpeg2 @ NTSC 29fps will import into DVDSP properly, but 24p gives an invalid framerate error (23.98 rather than 23.976). ffmpegX displays the proper framerate (NTSC Film), but doesn't produce (at least for me) valid output.
29.97 works fine, but you lose the advantages of progressive video. ffmpegX .7.something (early .7) worked fine, but hasn't worked in .8-.9. I've played with hexediting m2v files (the svcd->dvd hack) to check proper framerate, but no luck making it work.
Suggestions?
Great job with ffmpegx. It produces higher quality (visuall superior) results than Apples origina mpeg2 encoder, or the new Compressor tool. ^5
DNxHD .mov thumbnails not generating
By Flynn in forum Newbie / General discussionsReplies: 17Last Post: 13th Feb 2012, 18:39 -
Authoring HD/720p to SD-DVD: Render to 24p or 60i?
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 29th Nov 2011, 00:52 -
24p source to 24p DVD - am I doing it right?
By Killer3737 in forum Video ConversionReplies: 30Last Post: 14th Oct 2011, 17:40 -
24p -> pal -> ntsc back to 24p
By StrobeLightEpileptic in forum Video ConversionReplies: 1Last Post: 13th Aug 2009, 23:56 -
DVD Authoring with 2 HD Camcorders - Adobe or Vegas? 24p? Compression?
By Jamey5k in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2007, 14:18
