Ok I just recently got a dvd brunner (NEC 1300a) and have been reading the how to guides on certain topic. What I want to do is to convert an xvid file into mpeg 2 to play on my PS2. All the guides that I have read say to seperate the audio from the movie and convert the audio seperate. First question is can someone explain to me why you need to do this. Also I would like to know if I could just use vdub mod to do this.
Results 1 to 13 of 13
You separate the audio from the video to keep it in synch when you author it DVD. Select File-->Save wave to save the wave.
Hello. -
So can I use vdub mod to do it all for me? Or di I still need to seperate the audio from the movie?
You still need to separate the audio. You just need Virtual Dub to separate it, or Gold Wave. the choice is yours.
Hello. -
You will another program. Virtual Dub will frameseerve it to another program, like TMPGEnc, but you will only need to encode it once when you do this.
Hello. -
I've always been confused by this one. EVERY SVCD or VCD I've done with seperated Audio and Video has sync issues. When I leave them combined it works every time.Originally Posted by Tommyknocker
LS -
You do if you have synch problems. If it causes synch problems for you, then by all means avoid it like the plague.
Hello. -
I heard on another forum that win 98se will not reconize a 4 gig file. Can this be done on 98 se or am I just deluting myself?
does anyone know if I can convert an xvid file to mpeg on a win 98se system or do I need to upgrade to xp?
I have tried for about 7 hours last night and got random invalid page fault errors.
Simple guide for Virtual Dub Mod 1.5.10.3
By s_joy09 in forum Newbie / General discussionsReplies: 35Last Post: 31st Jul 2010, 16:33 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 08:18 -
joining problem with v-dub mod
By agent222 in forum Authoring (DVD)Replies: 4Last Post: 2nd Mar 2009, 09:18 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
