1. what is the best program to make a 1:1 copy of a DVD (directly from my DVD rom to my DVD writer)? I tried recordnow but it stopped at 30% and said error reading from source or something like that, but I know that the source CD is fine, I just burnt it and watched the whole movie fine.
2. what is the best program for resizing your DVD. Like from 1.85:1 to 16:9 or 2.05:1 to 16:9. or is there even one? and would you lose a whole lot of quality?
1 Use Nero, RecordNow DX, Ez CD Creator or any burning software that is DVD disk to disk enabled. Copying on the fly is not a reliable way to copy a disk tho. Most folks have problems, and end up copying to the HD first.
2) No ideer. Butchering up a perfectly good movie is all you'd accomplish if u try to change it from wide screen to full screen or sumthin like that. -
You cant copy directly from a (CSS protected) DVD to a DVD-R, most burners will do it (assuming the DVD is less than 4.4 GB) but youll end up with an unplayable DVD-R.
DVDs contain CSS encryption that must be removed first..(ie with DVDdecypter) -
Andy...if you read his first post closely, he mentions that he had just burnt and tested the source disk, so there was no encryption involved. I missed that part the first time I read it also.
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
program help
By Kanyeeeze in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2008, 08:16 -
What program do I use?
By adrian2055 in forum EditingReplies: 8Last Post: 6th Apr 2008, 02:50 -
Does anyone know a program that does this?
By dcsos in forum AudioReplies: 6Last Post: 10th Jul 2007, 06:05
