I have some Vob files for a dvd that I'm going to burn. The movie is in letter box format. Is there a way to change it movie from letter box to full screen without having to rencode the movie?
Question: when you say "full screen" do you mean full-screen/modified to fit your (square) TV screen? Or anamorphic wide-screen for 16x9 TVs?
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Originally Posted by j1d10t"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
So you want to take a wide-screen movie (be it letterboxed, or anamorphic), and crop off the sides to make it "full-screen" on your TV? Is that correct?
Zefram Cochrane
2073 -
VirtualDub has plugins that let you zoom so I think you could do what you want. You would need to convert the video to avi which will be a pretty big file. I would suggest you try it with a short clip first.
I haven't done this but I'm curious if it would work so let us know if you have any success. Real pan and scan is done by having someone watch the movie and move the cropped area around to keep the action centered but in most cases the action is in the center any way.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Mediacoder - Letter box / Crop to resize to add subtitle ?
By kehn in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2009, 12:52 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
Remove Letter Box
By Chala in forum Software PlayingReplies: 11Last Post: 21st Apr 2009, 21:52
