Hello, All;
I seem to be having a tough time of it with exporting my Final Cut Pro 2.0 session to MPEG2. When I open up the files in DVD Studio Pro 1.0 and try to set chapter points, the audio seems to slip out of sync over the course of the encode; it's a few seconds at the end of an hour.
I know this is analogous to the slippage you'll see if you have a problem with drop frame/non-drop frame timecode, so I've tried to set my & "timecode" tab in the "preferences" section several ways before exporting: set to drop frame/non-drop, etc. Am I barking up the wrong tree? Is this a common issue? I don't know if it makes a difference, but in the editing bin I've got, the length for the sequence is always in a semicolon format (denoting drop-frame TC) and the length for the clip itself is always in colon format (denoting non-drop).
Thanks very much
DVD Studio Pro's previewer is extremely buggy. Are you experiencing this problem in the viewer, or in the images you've built &/or formatted?
-r -
I could probably help, but what's all that junk in your message? Hard to read.
I cleaned it up a bit, now its much easier to read 8)
Thanks for the cleanup, Galactica!
I'm seeing the drift in preview AND when I burn test discs, so it doesn't seem to be a preview difficulty (though as a side note I have noticed preview mode being off at least once in the past. Is there any way to fix that? Is it seemingly random?)
Thanks for the help, folks!
Premiere pro 2.0 export DVD problem
By meekochan in forum Video ConversionReplies: 3Last Post: 21st Nov 2008, 17:55 -
Premiere Pro Export setting?
By peconi in forum Authoring (Blu-ray)Replies: 12Last Post: 4th Nov 2008, 11:07 -
Premiere Pro CS3 export
By kippard in forum MacReplies: 0Last Post: 11th Oct 2008, 20:33 -
very slow export from premiere pro 2
By yunakokimama in forum Video ConversionReplies: 5Last Post: 27th Mar 2008, 14:10 -
how to export MPEG4 from Premire Pro 2?
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2008, 01:36
