  1. Can anyone help me. I keep getting this one error.
    "CDRADO Write" execution failed:
    Try again first, Then
    Cannot determine status of inserted medium
    Writing Failed
    if anyone knows how to stop getting this error please let me know.
    Thanks.
    P.S. I have The Free Version
  2. Go to the settings/CDRDAO page and check that you have the force driver set correctly and the correct drive selected as the burner. Usually the Generic-MMC setting works. Also look at the bottom right of the panal , below the progress bar, and see if it says you have a valid aspi. If you have Roxio installed it should use the aspi from that. If not you can download the aspi from Roxio's website. If you instal nero it will say Nero Aspi. The exact file name is Winaspi32.dll Try going to the tools section of VCDHelp and putting in aspi as the search subject. You might also check the Settings/VCDEasy tab and make sure you have Enable CDRDAO integration checked.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ForceASPI usually does the trick. What OS do you run?
    /Mats
