My DVD's are coming out terrible ! So anyone who has any advise that may point me even close to the right direction would me appreciated more than you know.
I am new to DVD burning. I've burnt VCD with my old computer and were happy with there quality but these DVD's just aren't working!
I'm using a new Dell 4600, 80GB HD, 2.4 Gig processer, Graphic card is a 128mb DDR N Vidia Geforce Fx 5200.
Software is Dell Movie studio by Roxio and SonicMyDVD.
Problem: When the DVD is played it is extremely jittery and jerky looking. I notice when I知 transferring it from 8mm(Camcorder) to AVI it indicates that I知 dropping frames in the process. I suspect this may be the problem. Any fast motion is very jerky. This software allows me very few manual settings so there is no where I could even find to adjust anything.
Due to a problem I知 having with Roxio only putting about 2GB on the DVD then saying that its full, I use Roxio to capture and Sonic to burn the DVD痴. Sonics DVD capture ability I don稚 like very well.
I知 fitting just a little over an hour of digital 8mm to one 4.7 GB DVD is this normal?
So if anyone has any suggestions I will surely follow them. I致e spent 30 hours now trying to make this work and I知 at wits end. If I need to scrap this softeware and get something else that will work I値l do it. I have almost 200 hours of 8mm and VHS I have to place on DVD so even though I have 10 hours of DVD recorded to this point, I知 willing to start over so I can correct this problem.
Thanks again.
McQ
mccue@grics.net
your computer speed is fine, your software sucks.
if you are wanting to capture using a capture card, use vdub or iuvcr (other apps are available) and cap avi and then convert with TMPGENC or CCE. Take a look at lordsmurf's guides on capturing (even though you dont have an ati card).
with 200 hours to cap, I would suggest buying a standalone unit (panasonic e20, for example). For a number if people, they will get "better than the original" using a dedicated standalone unit.
Another thing on hardware, make sure you have a dedicated drive for capturing. you may get problems simply because you are capping on the drive the the os and everthing else is using.
I have capped and done the e20 thing. Will never seriously go back to capping. Just the occassional tv show.
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 22:59 -
Converting 8mm video to digital
By Victor Delta in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 17:27 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 13:24 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 18:51 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 21:28
