Hello. Is dvdxcopy better than dvd shrink? Dvdxcopy u have to pay for i know...but is it better?
Hi werewolf_02.
This kind of thread is understandably frown upon.
What is "better" from one's point of view might be "worse" for someone else.
My personal opinion, yes, DVD Shrink is better than DVDXCopy.
The only advantage DVDXCopy has over Shrink v3.0 is its ability to split to two DVD-Rs while keeping the menus (DVD Shrink can split too, but will not allow to keep functionning menus while doing so). -
DVD Shrink is a great software for ripping and shrinking, and I've seen reports that it CAN split a movie into 2 disks along with menus and all, but you have to re-author after the first disk.
Personally, I prefer DVD2One. Super easy to use, as long as you can do without all the authoring tools that shrink provides. Why someone would want to rip a movie with the menus is beyond me. If you own the original, just backup the movie. SO much faster and simpler. -
Okay great! By the info u gave me I think ill stick with Dvd Shrink. But ive heard Instant Copy can give better quality results. Can it? and does it take longer? cheers
Because sometimes it's just funner (I know, bad english) to see the menu's, like in Wayne's World, it looks like the satellite menu channel directory! Best program.........DVD SHRINK DVD SHRINK DVD SHRINK!!!!!!!!!!!!!!!!!!
This thread will never die's it's like "What's better AMD or INTEL" What better is what you want out of the software. Speed DVD2ONE. 1.1 copy DVDXCOPY. DVD2DVD or DVD2DVD-R best for movie's only. IC8 best for full disc back up. DVDshrink and DVDFAB best there free. CloneDVD very good also has burning software.
All these software have trail's so you can see if you like them.
Free Backup DVD software -DVDFab Passkey
By jimdagys in forum DVD RippingReplies: 3Last Post: 9th Mar 2010, 14:52 -
Driver backup software
By Tbag in forum ComputerReplies: 2Last Post: 2nd Mar 2010, 18:10 -
Hello All. I need a Free Backup Software to replace DVD Fab. Any ideas?
By Bamahusker in forum DVD RippingReplies: 89Last Post: 13th Nov 2009, 20:16 -
DVD Backup Software
By peebee23 in forum DVD RippingReplies: 7Last Post: 9th Jun 2009, 21:39 -
backup software
By alintatoc in forum ComputerReplies: 21Last Post: 25th Mar 2009, 13:23
